Home > General > Boot struts slipping off
Matt preece
United Kingdom 2013 Range Rover Sport SDV6 HSE Fuji White
Hi the boot struts on my13 rrs keep popping off only on the drivers side , it's done it a few times now I just pop it back in the ball joint . I was hoping there might be a fix to stop it reacuring
Post #598532 Mon May 04 2020 3:33pm
mrluke
Make sure the metal clips are still there , They shouldn't come off at all if the clips are there.
Post #598533 Mon May 04 2020 4:08pm
Silverstone
United Kingdom 2012 Range Rover Sport Supercharged HSE Baltic Blue
Had the same problem last winter. If the first time it happened it slightly bent the arm of the ball joint it will keep happening - even with the clip in place. There is no replacement for displacement - W O Bentley
MY2013 5.0 Supercharged HSE L320
Post #598534 Mon May 04 2020 4:44pm
Matt preece
The clips are still there but it still keeps popping out
Post #598587 Tue May 05 2020 8:02pm
