Home > General > fault codes ( lots ) |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
You can ignore u codes unless something isn’t working
Sat Sep 07 2019 2:52pm |
Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98 |
if not a wiring issue as suggested then it looks similar to an issue I had earlier this year - all modules were not communicating with one another ( 2 x A4 pages of same and more fault codes) but the fault was with the instrument cluster. Put a new one in and everything ok thus far....fingers crossed |
Sat Sep 07 2019 3:13pm |
dieselandruby Member Since: 07 Sep 2019 Location: yorkshire Posts: 4 |
ill definitely give it a shot mate , thanks for the heads up ! |
Sat Sep 07 2019 3:21pm |
touch wood for u mate!, was it an easy change , does a replacement cluster need to re programmed to the car etc? or is it just plug and play ? |
Sat Sep 07 2019 3:23pm |
I didn't do the work myself - the car was in the main dealers for weeks and the useless idiots there couldn't even do it so a couple of technicians had to come directly from LR to do it.
Sat Sep 07 2019 3:28pm |
ah ! silly me thinking something involving landrover would be straightforward ! |
Sat Sep 07 2019 3:30pm |
That's why we own them isn't it? |
Sat Sep 07 2019 3:44pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849 |
If/when it does it again, hit the top of the instrument binnacle and see what happens. 2019 5.0 SC SVA (Current)
Sat Sep 07 2019 4:18pm |
