![]() | Home > Technical > Brake light bulbs |
savi18 Member Since: 02 Aug 2015 Location: Gore. South Island NZ Posts: 148 ![]() ![]() |
Checked the brake light bulbs yesterday and has different makes fitted, so replaced with genuine land rover bulbs, could this have been the problem with loss of transmission fault errors on dash, looked at the posts from the past and have seen many saying could be brake light bulbs, seams hard to believe this could cause transmission errors, the brake light switch has been changed last year also. |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 ![]() ![]() |
Brake light bulbs can cause faults if they are faulty - replace them with LED globes and problems go away. 07MY RRS TDV6
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Brake light bulbs and the brake pedal switch are a good and cheap starting point. I Had ESF warning on my old D3, put genuine LR bulbs in and it didn't come back in the 7 years I had it. Theses are not normal cars. |
