Home > Technical > Random beeping
Simonhunt72
United Kingdom 2006 Range Rover Sport Supercharged Bonatti Grey
Random beeping
Hi all , so , the weather's been good so the parking sensors are working🤣 but I now have a random beeping from the rear of the car , quite faint and every 30 secs or so ,sometimes more /less , car drives fine ,no warning lights etc, any ideas as its bloody annoying, cheers all
Post #585755 Fri Aug 23 2019 6:25pm
hoppy_70
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Rimini Red
Is it possible that it has a tracker? Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Range Rover sport HSE Dynamic P400e Silver
Range Rover Sport 3.0 SDV6 HSE Dynamic 2016 MY
Range Rover sport 3.6tdv8HSE 2007 Gone
Range Rover sport 2.7tdv6SE 2005 Gone
Range Rover sport 2.7tdv6SE 2007 honey
Range rover Vogue 2005 4.4 - GONE and missed
BMW 535d M sport 2006 - GONE not as missed
BMW X5 4.4 2004 sport - GONE
Post #585765 Fri Aug 23 2019 8:40pm
Simonhunt72
Hoppy, no I'm sure it doesn't?! Its really only been doing it last couple weeks constantly, was quite random before , and nothing when I bought it!!!!!!!!
Post #585775 Sat Aug 24 2019 10:24am
Brit Plumber
Tow bar fitted? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #585779 Sat Aug 24 2019 1:46pm
Simonhunt72
Detachable yes , as in factory fitted brit
Post #585780 Sat Aug 24 2019 1:51pm
Brit Plumber
I wondered if it may have been aftermarket with one of those black boxes but not if it’s factory.
There is a small black speaker behind the right boot panel on the pillar, can’t remember what it is though. 2019 5.0 SC SVA (Current)
Post #585786 Sat Aug 24 2019 5:18pm
Simonhunt72
It's pretty constant now as well , even get double beep on turning ignition!!!
Post #585917 Tue Aug 27 2019 10:19am
What year is the vehicle? as the earlier cars had a speaker behind the n/s boot trim panel below the window for the parking sensors, not coming from that by any chance, could unplug it I suppose would at least eliminate it as a possibility.
Post #585918 Tue Aug 27 2019 10:38am
Simonhunt72
It's a 2006 model Col ,
Post #585919 Tue Aug 27 2019 10:51am
Simonhunt72
It's a 2006 model Col , and sensors are working ok ,at the moment!!if it makes sense it's a totally different noise to the rear sensor beep!!
Post #585920 Tue Aug 27 2019 10:52am
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
I'd go and listen to where the beeping is coming from then just remove the trim in that area, should be quite easy to find now its sounding that often. Then post a picture of the offending item.
Post #585921 Tue Aug 27 2019 11:09am
is it doing it when the car is still and or crawling along?
Post #585931 Tue Aug 27 2019 5:03pm
Simonhunt72
Andy k slowly yes, not sure on stationary
Post #585934 Tue Aug 27 2019 6:59pm
Is the noise coming from the dash?
When it happens press the P switch in the dash center and see if it stops
Post #585937 Tue Aug 27 2019 8:16pm
Simonhunt72
No it seem to be from the rear!
Post #585941 Tue Aug 27 2019 9:36pm
