Home > Technical > Rattle / clonk from rear
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
My 2.7 TDV6 has an annoying (to me Rolling Eyes ) rattle or clonk from the rear when I go over potholes. It doesn't always happen, only on certain ones. It's fine over slow speed humps.
I thought it was the rear hatch and have tried packing the lock, but that had no effect. I've just had a look underneath, and the exhaust doesn't make any noise if i wobble it. The only thing I could find that would make the noise are the big metal harmonic(?) dampers that hang from the very rear of the body. If I move them, they clonk on some thing that I can't see.
Has anyone noticed this and or found a fix for it ?
Post #585734 Fri Aug 23 2019 11:40am
I think I tied pipe insulation to the dampers. To stop this.
Also check propshaft center bearing
Post #585736 Fri Aug 23 2019 12:07pm
CornishRob
(Just in case anyone else has this), it's definitely the harmonic dampers (two big metal weights under the rear body, between the spare wheel and the bumper. I think it must be that the rubber bushes that they hang on have aged, and allow too much movement, so they hit either the bumper or a metal bracket on the underside of the boot floor.
I have wrapped some foam insulation around a bolt in front of the weights, then tie wrapped them to this bolt. I think they need several tie wraps, or they work loose. as they are quite heavy. Thumbs Up
Post #586550 Sun Sep 08 2019 6:11pm
CornishRob
Stopping the harmonic dampers swinging about so much has had a strange effect on the RRS. It seems much nicer to drive, with a noticeable reduction in vibrations from the rear when driving over rough surfaces, potholes etc. Shocked
Thinking about it, I suspect that the rubber bushes that hold the weights have aged and now allow too much movement, hence them "clonking" on the body/bumper. But it also means that the damper is not as effective at reducing the vibrations of the body over bumpy surfaces. At first I thought I was imagining it, but now I'm sure it has improved the ride.
I might think about trying to fit new bushes, if it's possible.
Post #586626 Mon Sep 09 2019 8:49pm
aaronjb
I think I've heard an occasional clonk from the back .. must crawl under there and have a look for these, what I now imagine to look like, Range Rover Testicles.. Laughing 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #586642 Tue Sep 10 2019 7:44am
