![]() | Home > Technical > Facia vents - arm keeps bending |
Does anybody else have a facia vent problem. The finger toggle works fine but the directional vents are pretty fragile. The connecting arm seems to disconnect at the slightest movement as the arm flexes and detaches it self so leaving the vent actually closed or the vertical planes facing in different directions.
Hah, I noticed I had the same problem the other day .. I wiggled it a bit and it popped back in.
