![]() | Home > Technical > Crossbars for the RRS |
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 ![]() ![]() |
It sounds like they should be correct - a similar set with the same part number was advertised on this forum last year (https://www.rrsport.co.uk/forum/post552289.html).
How are you trying to mount them? I’ve not fitted or even own a pair of these but I suspect you maybe trying to fit them incorrectly. I’ve a feeling the black trim needs to be removed out of the channel and these fit in there. Would you be trying to fit the across the whole roof to the door tops? 2019 5.0 SC SVA (Current)
Check this link
bstein Member Since: 12 Aug 2019 Location: Bergen Posts: 4 ![]() ![]() ![]() |
Thank you for your tips,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
I have genuine L/R roof rails and crossbars fitted to mine, although the crossbars are not currently on the vehicle I will dig them out and check what part number they have on them. The car is a MY13 but the rails/crossbars are the same on the 2005 through to 2013 Sport.
Much appreciated,
This is number marked on mine, total overall length, 2nd picture fully extended, 3rd picture fully closed, I will ask the question but I assume you are actualy extending both ends of the crossbars.
Thank you vert much,
