![]() | Home > Technical > My13 L320 tailgate opening failure |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
Personally I would be asking for them to get the correct part and fit that, especially as it’s a warranty job. |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
Well that's my view but apparently this is the answer from JLR tech support 2012 SDV6 HSE (technically its hers)
Why would the loom need cutting and soldering? If the part is so different that it needs a part loom, I’d be asking why!! 2019 5.0 SC SVA (Current)
Apparently the my13 cars have a different tail gate switch and actuator that isn't listed in the parts catalogue! I'm not quite sure I buy that reasoning personally. 2012 SDV6 HSE (technically its hers)
Really, I’ll check that out. 2019 5.0 SC SVA (Current)
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
If you are referring to the tailgate external switch situated between the rear number plate lights, it's certainly listed in the parts list as I replaced mine way back and my cars a MY13. I think you will find the switch is the same as Freelander 2 as well although the part number has been superceded from LR020997 to LR079909 there are also some extra wires in the new type switch which are not needed on the sport and can easily be removed if required. I do have a spare switch here and will double check that I have the right number. The latch and motor are also listed in the parts list, so I would be a bit sceptical about it not being listed on a 6 year old car.
Sadly nothing would surprise me with this dealer. It's only in there as they're close.
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
i replaced my my12 with a new external boot switch
