Home > Technical > Air compressor
mikewill53
United Kingdom 2006 Range Rover Sport TDV6 HSE Baltic Blue
Air compressor
Hi,
Ive just taken the wheel off my range rover sport and noticed the bolts for the bracket holding the air compressor arent tight... is this normal? ive attached some pics,
Thanks in advance for any help
Post #584457 Thu Jul 25 2019 5:44pm
Brit Plumber
They are on shock/silent mounts so should be tight but only to stop them undoing but not so the whole thing is rigid. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #584459 Thu Jul 25 2019 6:08pm
Brit Plumber
Could be some degrading to the rubber mounts 2019 5.0 SC SVA (Current)
Post #584460 Thu Jul 25 2019 6:09pm
gogsy1956
As per previous replies,, the rubber mounts should be securely fixed at each side,,, it's the rubber itself that provides the antivibration element. If the securing bolts were loose the whole unit would tend to jump about. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #584463 Thu Jul 25 2019 6:18pm
That's a AMK compressor and looks to me as the rubber mounts are shot, used to be able to get a mounting repair kit which had new rubber mountings, springs, washers etc. in it. Not sure if still available as expect L/R will want to sell you a new compressor assy. for a few hundred quid. BMW and Merc use amk so might be able to get something from them. If you could see that with just taking the wheel off, then the plastic cover is missing as well, 2006 car would probably been a Hitachi comp. originally and has been replaced by the AMK and the covers are completely different so probably never fitted a new one at something like £100+ for a couple of bits of plastic.
Post #584482 Fri Jul 26 2019 1:51am
mikewill53
Thanks for all the replies, much appreciated
Regards
Mike
Post #584801 Thu Aug 01 2019 11:59am
