Home > Technical > Boot and passenger door
Copey
Scotland 2012 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
Hi all.having a few small issues with opening the boot and passengers front door.
Car is a 2012.the passenger door will not open using the key fob.need to be in the car,reach across and flick the switch.
The tailgate however opens using the fob,and will not open using the touch button on the tailgate itself.
I understand there are only little issues but I’d like to have a wee shot at fixing them.
Any help would be great folks....thanks again
Post #581779 Sun Jun 02 2019 2:45pm
new latch mech for front door. (£30 ish ebay)
tailgate, need to see if the switch works, if its fine, check wiring exiting tailgate at top
Post #581782 Sun Jun 02 2019 4:32pm
Autobiography1969
My front passenger door has just started this on my 2012
Its strange as it unlocks sometimes but other times I also need to
lean across to pull the tab out,
Its almost like its tired,
a small spring behind it would make it work each time..
Might see if the warranty covers replacement.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #581784 Sun Jun 02 2019 6:35pm
knwatkins
My nearside front door did it and then my offside rear. A replacement latch in both solved the problem. Kev
Post #581786 Sun Jun 02 2019 7:15pm
