![]() | Home > General (L494) > How to remove ??? |
MBRRS Member Since: 03 May 2019 Location: Hertfordshire Posts: 29 ![]() ![]() ![]() |
How do you remove the window switch pack
Stevie7 Member Since: 26 May 2019 Location: Yorkshire Posts: 3 ![]() ![]() ![]() |
It will pop out using a trim removal tool. |
Invest in a set of these.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5033 ![]() ![]() ![]() |
I can't remember for certain but for some reason I though on the RRS2 there were a couple of screws underneath helping retain the drivers door switch pack, which meant the door panel had to be removed to remove it, as I say I may be getting completely confused with something else, but I would take care popping it out from the top to be on the safe side.
