![]() | Home > Technical > EPB Brake Shoes |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
No you don’t need that spring |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Have a couple of genuine L/R kits here and no spring like that is included in the kit, not sure whether that helps or not can't see it mentioned in w/manual either.
Cheers guys, I’ll not worry about it then.
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
The springs you mention are shoe balance springs and hold each shoe back from 'acting' at differing rates ( enening out the expansion if you like..). They can be Red and Green in colour, but have noticed that some fitting kits do not include them.
Yes your right the new ones are a green/black and a red. Did you leave them out? 2019 5.0 SC SVA (Current)
Yes. Left mine out as they were looking rusted and thin with total lack of tension.
Didn't realise you meant the small red & green one's, the one in the picture looks far bigger, the coloured one's are in the L/R kit but hardly look man enough to do any good, one off each colour in each kit.
Certainly look small to do anything, and cn only think they're there to help keep the shoes on the adjuster. 2011 MY D4 HSE
