Home > Technical > Inlet port deactivation
pre7amble
England 2006 Range Rover Sport TDV6 SE Giverney Green
Hi, whilst browsing the circuit diagrams for Electronic Engine Controls I see that there are different versions dependant on whether the engine is with or without inlet port deactivation, what is inlet port deactivation and how do I know if I have it?
Richard
Post #575444 Sun Feb 17 2019 2:02pm
Disco_Mikey
No T/SDV6 had port deactivation, it was only used in the Jag variants
Post #575447 Sun Feb 17 2019 3:11pm
pre7amble
Hi, thanks for that, don't know what it is but knowing I don't have it allows me to read the correct wiring diagram.
richard
Post #575454 Sun Feb 17 2019 4:50pm
Port deactivation is a way of improving engine breathing. You set up your pair of inlet ports in each cylinder so that one gives good swirl at low revs and the other gives cylinder filling at higher revs. You then deactivate the high filling port at low revs using a valve in the inlet tract.
It's a simpler version of variable valve timing, in effect.
The TDV8 does have port deactivation. 2012 SDV6 - it's missing a couple of cylinders
Post #575460 Sun Feb 17 2019 6:06pm
pre7amble
Hi, thank you for that simple and clear explanation. It also explains why my manual shows circuits both with and without.
Richard
Post #575466 Sun Feb 17 2019 9:02pm
