Home > General > Front timing belt
Iggy
United Kingdom 2011 Range Rover Sport SDV6 HSE Santorini Black
Front timing belt
Hi all.
is it normal for the cam locking pins to be tight after fitting the belt tensioner and re tightening the cam sprocket bolts..
I have locked the flywheel but I can move it a fraction and they loosen up enough to get them out.
Is this normal. I need to get this back together before I forget where it all goes.
Post #566251 Wed Oct 03 2018 10:16pm
sounds ok to me
you should be able to get them out
Post #566273 Thu Oct 04 2018 11:06am
Iggy
Hi all project nearing completion I seem to have what I believe is a vacuum pipe with no home anyone with an idea where it fits.
Post #566604 Wed Oct 10 2018 3:15pm
Iggy
Post #566605 Wed Oct 10 2018 3:16pm
Doesn't that connect to the air filter box below the air flow sensor at bottom left of the photo? 2012 SDV6 - it's missing a couple of cylinders
Post #566614 Wed Oct 10 2018 4:32pm
its helps if you fill in you car details in your profile.
engine and year
Post #566636 Wed Oct 10 2018 7:46pm
Iggy
Timing belt
Thanks for your help with that. I can't believe I couldn't see it. Hopefully I'll have it all done over the weekend and if all goes well I have a 2.7 discovery to do next. I reckon it's taken around 30 old man hours to do the front and rear belts.
Post #566744 Thu Oct 11 2018 10:43pm
