Home > Technical > Lumpy strtup and Smoking issue |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
The valves can temporarily be blanked off to isolate them
Sun May 20 2018 5:09pm |
RRSCruiser Member Since: 02 Apr 2010 Location: West Sussex Posts: 41 |
I saw that procedure in the LRO mag a few editions back and it seemed nearly the same amount of work to get in to blank off as it is to get and change, so I thought if I could compare the EGR valve live value trace from someone elses car that is working first, it gives me a better idea that there is a fault. Save a double bubble on labour costs
Sun May 20 2018 5:32pm |
That one would run relatively well once warm, albeit a bit laggy at the bottom end
Sun May 20 2018 7:21pm |
LOL, I wish we were not at the southern end of the country, need some of that experience
Sun May 20 2018 7:29pm |
Live values were 100%, as in the actual positions were a perfect match for the commanded positions
Sun May 20 2018 7:35pm |
Thanks Mike, I'm taking my spiky trace is not a good sign.
Sun May 20 2018 7:46pm |
Hi Mike
Sat Jun 02 2018 5:49pm |
bump, would be good to know if this is a reasonable way (see previous post in thread) to approach this or am I creating an issue |
Tue Jun 12 2018 7:01am |
