Home > Maintenance & Modifications > EGR blanking and new MOT rules
Zeoman
Scotland 2006 Range Rover Sport TDV6 HSE Siberian Silver
I know the EGR debate has been done to death, but in regard to the new MOT rules, is it worth blanking working EGR's? Has anyone who has blanked them off actually been caught yet?
Cheers Jon
Post #556494 Tue May 15 2018 11:48am
too early to say, but you may as well get it thru this years MOT first
and use discrete blanking plates
Post #556558 Tue May 15 2018 8:17pm
Bodsy
Site Sponsor
They can not visually inspect, so if they see blanking plates (assuming they know what they’re looking for) then it may be a fail.
I’ve always used blanking shims, so the pipework stays in place and is visually standard. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #556602 Wed May 16 2018 9:13am
Should read:
They can ONLY visually inspect
Post #556612 Wed May 16 2018 11:02am
SRE
Spain
Begs the question, when will they be able to plug into the vehicle diagnostics to see if the EGR's are functioning Whistle In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #556620 Wed May 16 2018 2:09pm
Disco_Mikey
As above. Visual inspection only.
If they look like they are fitted, and passes its smoke test, it will be fine Thumbs Up
Post #556650 Wed May 16 2018 5:41pm
They were talking about checking for ECU fault codes last year (or year before) and for checking for chipped cars, but didn't get introduced yet
Post #556663 Wed May 16 2018 7:38pm
Zeoman
So, I have a fresh mot and I want to blank my egr. I have seen 2 kits on eBay. One 2 piece and a 4 piece which has some seals fitted. I want to leave pipework in place. Also, on viewing the howto list I saw butterfly removal. May I ask the reason for this please?
Post #563133 Mon Aug 13 2018 4:04pm
Disco_Mikey
2 piece is more than sufficient Thumbs Up
Post #563138 Mon Aug 13 2018 5:49pm
wilf
While we are on the subject of MOT testing - does the stop/start system get checked at all? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #563150 Mon Aug 13 2018 7:48pm
Father Jack
If they start checking for chipped cars where would that leave me with my Alive reprogrammed ecu ? And the rest of us with similar mods ?
Post #563152 Mon Aug 13 2018 7:52pm
Disco_Mikey
Not at present Thumbs Up
Post #563157 Mon Aug 13 2018 8:21pm
Disco_Mikey
Not an issue at the moment, and not one that I can see even in the future. Too many variables and unknowns, and I expect a workaround would also be possible if the worst were to happen Thumbs Up
Post #563158 Mon Aug 13 2018 8:22pm
Father Jack
Cheers Mikey. Always appreciate you taking the time to post so often here and on the Disco site. Especially when you've got a busy garage to run.
Post #563161 Mon Aug 13 2018 8:48pm
DerrekL
If I decide to blank the EGR's on my EU4 07 plate do I have the specific patching software loaded on my IID Tool or do I have to purchase a software patch from GAP or other? Thumbs Up RRS 2.7 HSE Stornoway Grey
P38 4.6 HSE V8
Post #563679 Tue Aug 21 2018 1:29pm
