Home > Technical > engine oil
pinemarten
engine oil
When I bought my RR Sport 2011 they had just serviced it. I asked what engine oil they had used as I don't like to mix oils if I can help it. They told me they had used Petronas syntium 5000 FJ 5w-30.
However I don't seem to be able to find the exact spec. FJ seems to be the problem the ones I have found have different letter here. Is it just the same but upgraded or does it mean nothing. Reading past posts I see the oil must have a spec of M2C934-B The oill I've found has a spec of M2C948-B. Is that better, different or no good at all. When did buying oil become such a minefield
Post #532418 Wed Aug 09 2017 12:43pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
As far as I know MC948B is a 5W20 oil. that grade would be totaly wrong and should not be used! RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #532429 Wed Aug 09 2017 3:45pm
Hog
Shocked RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Post #532430 Wed Aug 09 2017 3:46pm
pinemarten
Thanks for the warning. Just got to find the right one now. I'd go back to the garage I bought the car from but its over 100 miles away. Lond way to go for a litre of oil.
Post #532454 Wed Aug 09 2017 8:29pm
If you aren't off roading it; as long as it's on the dipstick. It's fine.
Or u not got a dipstick?
Just get any 5w30. C3
Post #532455 Wed Aug 09 2017 8:44pm
Johnski
As stated already and don't know why it would have been put in a RRS. It is a Fully Synthetic Oil made by a few companies see link: http://www.opieoils.co.uk/c-2125-ford-wss-...e-oil.aspx
Copied this from Opie Oils.
"Produced in 2012 for Ford 1.0L 3 cylinder EcoBoost petrol engines and also for the 1.25 16V, 1.4 16V, and 1.6 Ti and 16V EcoBoost's. These oil's when used in conjunction with Ford Eco engines produce high MGP. Oils that meet this spec are of low viscosity, normally around 5w-20" John
Post #532458 Wed Aug 09 2017 9:44pm
riverblanche
Hi,
your not saying Why you need the oil Question does it need topping up already (possible leak) or are you just getting a litre for Just in case.
wait for Tesco to have their oil offer on again Rolling Eyes
Although if the wrong oil Is in, maybe do a complete oil change for piece of mind and put in what you know is correct and you can source easily
Post #532462 Wed Aug 09 2017 10:34pm
See my reply to your other post about this same subject. Go to Halfords and get Castrol Magnatec A5 or Halford's own version thereof.
If you need to top up more than a tiny drop now and then, you're probably looking at a bigger issue than the make of oil. 2012 SDV6 - it's missing a couple of cylinders
Post #532465 Wed Aug 09 2017 10:48pm
Page 1
APPLICATION
Syntium 5000 FJ 5W-30 is suitable for use in petrol and diesel engines that require ACEA C1 lubricant.
Syntium 5000 FJ 5W-30 is suitable for use in vehicles that a 5W-30 lubricant meeting Ford WSS-M2C934-B
Specification.
SPECIFICATIONS
SAE 5W-30, ACEA C1, FORD WSS-M2C934-B
RESEARCH & DEVELOPMENT
02/2015
TECHNICAL CHARACTERISTICS
SYNTIUM 5000 FJ 5W30 (UK ONLY)
PRODUCT CODE: 1852
As stated M2C948B is a 5w20 for the 5.0L Petrol Engine.
Post #532483 Thu Aug 10 2017 9:23am
riverblanche
Hi,
pop in Tesco get 5w-30 C1 or C3 for top up
or
better still get 4 bottles and do an oil change and have some left if needed
Post #532512 Thu Aug 10 2017 6:05pm
