Home > General > Steering wheel wobble
Socast
If your wheels are true and balanced, did you over/under tighten the driveshaft capture nut ?
The brearing has four bolts holding it in place, are these all tight and were the mounting faces clean ?
Post #532390 Wed Aug 09 2017 8:50am
DEVON
UPDATE ......
Replaced the wheel bearing today with a new unit , and glad to report the "wobble" has gone ,
and the smile has returned to my face Laughing
The old unit (Timken) was found to be at fault, running slightly out of true, whatever that means ?
To be fair the original supplier exchanged it without quibble .
A big thanks to you all for your advice Thumbs Up
Post #532685 Sat Aug 12 2017 8:30pm
