Home > Technical > DSC Issue |
Did you have a full four wheel alignment carried out at a centre equipped with Hunter kit after the suspension work?
Fri Jun 02 2017 4:45pm |
Burns Member Since: 02 Nov 2014 Location: Shropshire Posts: 29 |
Solved, low tyre pressure at rear due to slow air leak. It's now been repaired and the problem has gone. I didn't realise the system was so sensitive šš» Diesel sport BAS remapped by Bodsy
Thu Jun 08 2017 4:43pm |
