Home > General > RRS Bonnet not closing properly?
Sgthomer99
My 2005 RRS will not allow me to secure the bonnet after I topped up the washer water. I've tried everything including how it says in handbook (gently pressing it down with 2 hands) to trying to slam it down from a height, both without success. Any ideas anyone??
Post #518227 Sun Feb 19 2017 2:06pm
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Re Bonnet not closing
Hi Sgthomer99
I have had this with mine a few times,Sometimes one catch and not the other will lock. If this is the same problem with yourself. I just soaked the catch in the landing panel with WD40 and worked the release cable from inside the car a few times and then they worked as they should.
Hope this helps Thumbs Up
Post #518251 Sun Feb 19 2017 4:49pm
Unsure the release handle inside has returned. Push it in.
Then give the bonnet a slam Laughing
Post #518253 Sun Feb 19 2017 4:57pm
hafman
I have this all of the time on my L494 - the lever in the footwell does not return properly, causing the catch under the bonnet to not work. Solution has been to push the lever back and then close the bonnet. #irritating.
Post #518255 Sun Feb 19 2017 4:59pm
Sgthomer99
Thanks all for your advice, will hear in mind for future. After about an hour and much annoyance to neighbours, have finally locked the bonnet Shut! Memo to self .....don't open it!😀
Post #518276 Sun Feb 19 2017 7:09pm
Topsy
Wales 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi
I had the same problem recently on a 300 mile trip in gales. Not one of my favourite experiences waiting for the bonnet to fly up, particularly as the previous journey had been spent with the well known suspension dropping problem!
I needed to use a screwdriver to shift the mechanism where the hook clips under the bonnet. WD40 to release it but remember to use grease to coat it once free. WD40 will release it but won't last as a lubricant (sorry if you already knew that)
The above also solved the problem of the lever not returning to place on mine.
Good luck
Post #518284 Sun Feb 19 2017 7:25pm
Bobby
Re: Re Bonnet not closing
Jock 77 wrote:
Hi Sgthomer99
Be careful with the WD-40...
http://www.rrsport.co.uk/forum/post285080.html#285080
Laughing Laughing Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #518440 Tue Feb 21 2017 5:14am
shakeapaw
just buy new catches, I got a pair from my local indie for about £50, took an hour to fit 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #518669 Thu Feb 23 2017 1:23am
Sgthomer99
Thanks for all the advice folks, noted....Update to last....travelling home from work today at 65mph in outside Lane of dual carriageway the bonnet decided to unlock, luckily the safety catch held and prevented a nasty accident, pulled into lay bay and shut it again. A bit wary now!
Post #518754 Thu Feb 23 2017 8:33pm
