![]() | Home > Technical > Remap Options |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Maybe you should have purchased a BMW or Astra |
My Discovery has a Stage 2 map by Alive
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Most of the time i chug around and would prefer MPG gains over HP for everyday use, but every once in awhile I'll see a nice stretch of road or simply want to got WOT to scare the wife. |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1184 ![]() ![]() ![]() |
a normal Stage 1 remap will give you better consumption if you don't drive it like a hooligan.
Your MPG is directly related to the position of your right foot ![]() |
Disco_Mikey is 100% correct
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 316 ![]() ![]() ![]() |
DM is totally correct. A decent map will give economy if driven gently and performance if driven hard.
I appreciate that a re-map will most likely give an increase in mpg when driven sedately, however the throttle response is quite sharp. If you have a more balanced/stock map you don't have to worry about blipping the throttle while on rough/wet roads and nailing yourself to the back of your seat or spinning out.
Just buy a SVR & you will have loads of power,,550 horses then have it mapped to 575 |
Would if I could.. |
haha, relax dude, no one's saying you're a chav/boy racer, etc.
double post,,can someone delete this pls Andy.
I think you might be overreacting a little, I assumed the comment about buying a BMW was for the eco mode which adjusts map and throttle angle, not about calling you a chav! Everyone else was just explaining why you generally dont need two maps, and thus theyre not normally offered (Plus offering it on a stock ecu generally involves flashing custom code into the ECU).
ozzievechi Member Since: 14 Mar 2016 Location: london Posts: 55 ![]() ![]() |
quite a fair question to be fair:
