Home > General > Strange noise on front of 2007 rrs help
Tizzard
Hi all. Bit of a odd one but don't no if anyone has had this before. I have a 2007 rrs and the past couple of days I've noticed a squeaking sound coming from the front end when going over speed bumps. Sounds like a dry bush. But then after driving the car for ten mintutes the sound goes and the car is fine for the rest of the day. Get in the car the next day and same thing again then goes. Can anyone shed any light Thumbs Up
Post #511667 Tue Dec 06 2016 6:29pm
DrRob
Bush warming up as it's worked? Worth getting g on a ramp and use a pry bar Visitor from fullfatrr.com
Post #511668 Tue Dec 06 2016 7:43pm
Tizzard
To be fair I don't think I would find it with a bar as normal bumbs in the road it's fine it's just the high speed bumps when going over them. But why would the cat be fine to drive for the rest of the day? Even if I park it up for 3/4 hours then still fine when I get back in it Mad
Post #511670 Tue Dec 06 2016 7:57pm
R1guy
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
I had the exact noise from the front on speed bumps, like a creaking garden gate. It was the center anti roll bushes.
Post #511683 Tue Dec 06 2016 9:11pm
Tizzard
Thanks for the advice When you say centre bushes do you men the ace bar bushes as I had a new ace bar and bushes fitted 10minths ago. So shouldn't think it should be them already as the hasn't even covered 2000miles since all fitted
Post #511695 Tue Dec 06 2016 9:53pm
R1guy
yes the center bushes weather standard or active roll bar fitted. I would expect them to last longer than 2k, but not unheard of to fail very early.
Could it be a ball joint I wonder? Or drop links?
Post #511767 Wed Dec 07 2016 7:52pm
B9BS X
Had the same problem too, turned out to be the front anti roll bar bushes, common fault, quick and easy repair to get rid of the creaky noise Thumbs Up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #511777 Wed Dec 07 2016 9:04pm
Tizzard
Well I got home from work last night and sprayed wd40 on the drivers side bottom wishbone bushes and also on the ace car bush. Took the car out and no squeak. So I will wait for it to come back then spray one bush at a time to determine what one it is. Cheers for the input everyone Thumbs Up
Post #511804 Thu Dec 08 2016 7:50am
