Home > General > Vibration and steering wheel shake
l200jmc
Hey guys, Im getting wheel balancing vibrations at 50 or above and when light breaking getting steering wheel shake. Also if I hit pot hole I get the shake through the steering wheel.
I have had 2 new bottom arms fitted with bush and ball joints 4x anti roll bar bush's, a new hub and 4 new tyres and am still getting this problem...and also wheels balanced.
Any ideas it's driving me crazy
Post #498622 Tue Jun 14 2016 1:45pm
Jimbob36
Me too! Had everything done. I suspect steering rack as prone on the first model tdv6. Only just got car so want sorting.
Post #498624 Tue Jun 14 2016 3:05pm
l200jmc
Such and pain in the *** ain't they mate. Mines the tdv8 on a 57 but shes got a few miles now Sad
Post #498630 Tue Jun 14 2016 3:52pm
Jimbob36
It's been back and had turbo actuator, 2 tyres, front discs, alignment and balancing. Still there!
Post #498638 Tue Jun 14 2016 5:10pm
Loco98
Ireland 2012 Range Rover Sport 3.0 TDV6 HST Santorini Black
Have the same issues myself. Garage have tried everything to sort it. Suspension is fine. Rack is fine. Tracking and whelel balancing. Changed discs all round. EPB shoes. I think it's a sticky caliper myself but they said they are fine. Funnily though after the last time it was in I checked the wheel nuts a few were slightly loose. I tightened them up and did have a blast at the garage. Funnily about a week later I found 3 that had slightly loosened again. It's like a quater turn loose. Have ordered new wheel nuts.
Post #498711 Wed Jun 15 2016 1:21pm
l200jmc
These cars are nothing but headache's or at least mine is lol, I've noticed I have a bit of play in the steering wheel, which can be felt when going over bumpy terrain.. If anybody knows what it could be
Post #498720 Wed Jun 15 2016 5:22pm
mac01642
United Kingdom 2007 Range Rover Sport TDV6 HSE Fuji White
currently going through the same, this only started happening after new brake pads where fitted.... following fitting I had a sticky caliper which cause dover heat. this weekend im changing discs and callipers. I will let you know how I get on.
Post #498865 Fri Jun 17 2016 2:58pm
Be helpful if you filled out your profile so we all know what version of RRS you're driving in future threads. Thumbs Up
My TDV8 is starting to feel loose in the steering too. I think it's getting ready for new struts (the ride is a bit brittle these days) and I'll probably throw new arms at it too. After 130,000 hard miles and nearly 9 years I think they're due a change. Although the front lower arms have been changed before I think a full set might be a good plan.
In your place, I'd start with a new set of lower front arms. They're the usual wear items at the front end. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #498885 Fri Jun 17 2016 5:23pm
Bounce
I had all these issues after new pads were fitted,wheel vibration,sticking calliper etc.After 3k miles it seems to have sorted its self now,must of been a misshaped pad.By the way it's a 2006 2.7. Cool
Post #498917 Sat Jun 18 2016 6:31am
Loco98
What I have found with mine is that the wheels are losing balance after a couple of weeks. Got them balanced 2 weeks ago and all vibrations gone. Now they are now going out of balance again. What would make them keep losing balance.
Post #504345 Fri Sep 02 2016 7:44am
Jimbob36
Same as ours was! Weve now lost patience with it and it has been rejected as not fit for purpose. Engine fault came back again after 2 weeks. Turbo, map, maf, csv all replaced and it still did it ! Most unreliable car we've owned! Won't be having another one! Back to defender td5 for us!
Post #504348 Fri Sep 02 2016 7:59am
BKHK
It sounds unlikely and it was the subject of many posts back in 08-09 however, my persistent front wheel wobble was eventually traced to the rear diff.
At the time, the car was under warranty. I had new tyres, new wheels, new discs, new pads, new steering rack, more wheels with more new tyres, an almost permanent attachment to the wheel balance machine and eventually a replacement car.
But the problem was eventually fixed with a new rear differential. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #504369 Fri Sep 02 2016 12:41pm
