Home > Technical > battery and seized turbo advice required.
bgasmatt
Range rover sport 2.7
took the car out today and got fault code turbo under pressure on the snap on so jacked the car up and the actuator was seized open after getting this resolved i lowered the car went to go on test drive and battery light was on so i plugged the solus back in and got code p0625 generator field too low.
voltage across battery 13.3-13.6 occasionally jump to 14-15 volts so guessing alternator has gone but is this just coincidental.
thanks in advance.
Post #488438 Sun Feb 21 2016 7:24pm
Lost for Words
Yep, sounds like the alternator's had it. Make sure you fit an OE Denso. Thumbs Up
I suppose there's a small possibility that it's related, but I think I would assume otherwise. Visiting from DISCO3.CO.UK
Post #488486 Mon Feb 22 2016 10:16am
