Home > General > Limp mode
kevtydd
Wales 2008 Range Rover Sport TDV8 HST Java Black
Limp mode
Have a problem hopefully with a simple fix ! RR has gone into limp mode about 5/6 times in last 10 days ! Suspension problem comes up on screen but stop , turn off engine and re-start and re-set suspension to normal height and things are fine . Wondering if this could be linked to having 2 new front tyres 10 days ago ? Mrs took car in but confirmed that they just jacked car up to remove wheels ? I thought suspension had to be in off-road setting ? Would a hard re-set sort things ? thanks in advance !!! Sad Sad Sad
Post #483067 Mon Dec 21 2015 7:33pm
Camelrock
Was car ok before the tyres where fitted ? Did they check adjust tracking when the tyres where fitted ? Car needs to be plugged in and fault codes checked.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #483082 Mon Dec 21 2015 10:58pm
kevtydd
Car was fine before . Just looked at car now after it's been standing for 3 days and all corners are level and it's at the height it was left at
Post #483130 Tue Dec 22 2015 8:04pm
