Home > Maintenance & Modifications > "Follow me home reverse" activated with IIDTool no
rhenus132
Germany 2006 Range Rover Sport TDV6 HSE Lux Stornoway Grey
Hi,
i have activated the function Follow me home reverse" but only the front light is working when take the key...
Does that function mean the rear white lights will also switched on?
Best regards
Frank
Post #464558 Sun Jun 14 2015 9:01pm
Bodsy
Site Sponsor
You need to program the key to use the lights. It only works on the lr button, press it twice, first time front lights some on, second time reverse lights come on. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #464569 Sun Jun 14 2015 10:02pm
rhenus132
Ah ok, thanks...actually i am opening the back door (trunk) with the LR button...
how to program the key on the home lights?
Post #464579 Mon Jun 15 2015 5:54am
Bodsy
Site Sponsor
Hold the LR button down for 5 seconds, keep it held down and then flash your main beam lights by pulling the stalk.
That should now be set to lights on using the button. Bodsys Brake Bible
See it HERE
Post #464586 Mon Jun 15 2015 7:41am
rhenus132
Done..and working....funny gadget...Wink
Post #465741 Thu Jun 25 2015 8:41pm
