Home > General > Slow leak on one side of range rover sport |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
First thing is to remove the air suspension controller fuse having ensured the vehicle is sat at the correct height. It's number 26 in the fuse box next to the battery. It's a 20A fuse.
Fri Feb 20 2015 9:42pm |
ziglo Member Since: 20 Feb 2015 Location: channel islands Posts: 19 |
Hi,
Fri Feb 20 2015 9:51pm |
Hi RRSTDV8
Wed Mar 11 2015 6:56pm |
Simon73 Member Since: 20 Apr 2014 Location: Lichfield Posts: 23 |
same problem with mine they replaced compressor then airbag then some other stuff before finally replacing crossover valve that seemed to sort it fortunately all under warranty. |
Fri Mar 13 2015 11:25pm |
The front and rear valve blocks do indeed each contain 3 valves. One corner valve for each airbag and a crossover valve that allows air to move between airbags on the same axle. The systems uses the individual valves to raise or lower the individual corner. It uses the crossover valve to allow air to move across the axle to improve articulation off road and comfort on road at low speeds. Here is what the valve block looks like:
2008 TDV8 - it was a labour of love and is much missed |
Sat Mar 14 2015 6:59am |
thank you RRSTDV8, currently on order is the rear crossover valve and a rear sensor.... since my mechanic has had it he cleaned out both front and rear valves gave a little tighten on a hose after that he gave me it back I parked it and 5 hours later the passenger side had dropped leaving it all lope sided so I then started it up it leveled switched off then pulled the fuse that you told me after a day the whole rear of the vehicle dropped about 40mm whilst the front didn't budge, this made no sense as before mechanic had it it was a front issue but maybe he sorted that with what he done.
Sat Mar 14 2015 2:23pm |
Update - Mechanic has changed rear air block (crossover link) he also changed rear sensor and so far it's sat perfect not budged after 24 hours parked up and also after using and parking on different terrain so looks like it was the rear valve after all, thank goodness it was the cheaper part thank you for your advice on this one only one last job to do pre-sale and that's the anti roll bar bushes. |
Fri Apr 03 2015 5:00pm |
2012 SDV6 - it's missing a couple of cylinders
Fri Apr 03 2015 5:36pm |
RainHard Member Since: 07 Sep 2013 Location: Lonehill Posts: 20 |
Hi All,
Thu Feb 27 2020 4:25pm |
