Home > General > What are this marks on the dash? |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 |
You'll find faults and common problems with every car. Its just the Range Rover bits cost more to fix and usually take longer labour time.
Wed Feb 11 2015 8:34pm |
Just looked at your picture. I've never noticed the lines as clear as that in mine. Are you saying 2 different cars both have the same lines? I'm not Fat. RRS TDV6 HST. |
Wed Feb 11 2015 8:38pm |
grrb Member Since: 11 Feb 2015 Location: Cancun Posts: 3 |
Yes they are completely split! honestly it looks like its been cut exactly where the airbag would open, so I would have just said it was crashed, but then I just found this in another forum, its an LR3 dash, apparently its common, and its similar but not as drastic. And that got me thinking maybe its not the airbag and just a problem with the vinyl on the dash.. and I did see this in 2 cars, so I wanted to check with you guys
Wed Feb 11 2015 8:47pm |
I've seen stuff like this in lots of cars, sometimes if there in the sun for long periods the leather might sag a little however I haven't noticed this in mine or at least nothing that noticable. I'm not Fat. RRS TDV6 HST. |
Wed Feb 11 2015 8:54pm |
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 |
This is the sacrificial segment of the airbag covering vinyl and it's a huge problem in the Middle East that Land Rover refuse to address. The dash facia material isn't UV resistant enough and over time these cracks will split wide open like a crushed water melon....just about every one of my mates with RRS and LR3 (Discovery 3) have this same issue in Dubai.
Tue Feb 17 2015 6:57am |
Just checked mine for you and you can faintly see the lines. Very faintly though so I believe its just the sun that makes it worse I'm not Fat. RRS TDV6 HST. |
Tue Feb 17 2015 10:12pm |
You're lucky...under the Middle East sun we've seen dash boards that are completely destroyed because of the wrong grade of materials used. This is a serious flaw that Land Rover refused to acknowledge as a defect.
Wed Feb 18 2015 5:12am |
Simon73 Member Since: 20 Apr 2014 Location: Lichfield Posts: 23 |
which explains why so many cars over there have carpet put on the dashboard lol |
Fri Feb 20 2015 11:08pm |
