Home > General > 2006 2.7 Engine sound.
CRA165X
Hi guys,
I have noticed since buying my RRS that when engine cold it sounds nice and meaty but when the temperature gets up there it starts to sound abit knocky/tappy.
I had the oil and filter changed a week ago but still sounds the same?
Any ideas guys?
Cheers Craig
Post #446401 Thu Dec 25 2014 6:39pm
Bodsy
Site Sponsor
The 'nice and meaty' noise is just the Viscous Coupling fan. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #446405 Thu Dec 25 2014 7:40pm
CRA165X
Haha well it sounds an amazing machine when cold and the viscous is going but then a loud diesel later on lol.
Post #446406 Thu Dec 25 2014 7:43pm
CRA165X
Anyone??
Post #446443 Fri Dec 26 2014 7:49pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Confused
Bodsy just answered your question. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #446444 Fri Dec 26 2014 8:06pm
simple1
New Years resolution for this one. No more drunk internetting Rolling with laughter 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #446457 Sat Dec 27 2014 9:57am
CRA165X
Haha yes no more Corona while typing.
But sorry i dont think i made my self clear.
What i ment was when the RRS is cold the engine sound nice and strong but when it gets to temperature it sounds really tappety and knocky if that makes sense. sounds like an old tractor when the oil seems to get hot and thin.
Can i try a slight thicker oil and see if it makes any difference or is that a bad idea?
I have also found out that my RRS had a brand new engine in May 2012 at Guy Salmon Maindstone so has only covered 20k at the moment.
Cheers Craig
Post #446860 Wed Dec 31 2014 9:14am
simple1
Ah I see.
Doesn't sound right, the hydraulic tappets do become noisey but not to tractor volume unless there is an oil feed problem. The oil must remain the same, if you play it will show up if they test oils.
If it were me, I'd land it to a dealer and let them diagnose it then you can involve LR if there is something wrong. Our disco gets a bit tappy when it's due an oil change but never sounds harsh. Other possibility is a sensor is going down and injector timing isn't spot on causing a knock.
Get it checked out. Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #446862 Wed Dec 31 2014 9:23am
CRA165X
Cheers for the advise much appreciated.
Yes will get it booked in ASAP.
I have got a little OBD2 computer and had a little plug in and no faults where showing, and its not under powered or anything so fingers crossed it will be something simple i hope anyway.
Thank you again
Craig
Post #446865 Wed Dec 31 2014 9:35am
