Home > Technical > Air con blowing warm |
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 248 |
Although you have had the system regassed, was it pressure checked for leakage? probably got a stone chip in the condenser, so your new gas has leaked itself away, the compressor will only work if the system pressure switch detects gas pressure in the system...
Fri Aug 08 2014 8:08pm |
Jonesyscoob Member Since: 21 Oct 2012 Location: Birmingham Posts: 95 |
Thanks can the same people do that test? Just local garage that did the gas fill |
Fri Aug 08 2014 9:33pm |
Have had a poke round today there is no gas in the system so must be a leak somewhere as not used since regas, is there any common leak places?? |
Sun Aug 17 2014 2:04pm |
