Home > General > front arc bush. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Undo the 2 front bolts of the clamp, and remove the chassis member underneath to change the bush |
Sun Jul 27 2014 9:31pm |
scott1963 Member Since: 27 Jul 2014 Location: scotland Posts: 18 |
thanks for that.is it easy to take cross member off. |
Mon Jul 28 2014 3:23am |
Hi sorry i have the active cornering installed in my range rover sport anti roll bar.
Mon Jul 28 2014 3:38am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
Anything is possible if you have the money to spend. I doubt it would be cheap/easy to replace the dynamic roll bar as it's linked in to the overall stability control and terrain response systems.
Mon Jul 28 2014 12:02pm |
Hi just thinking it would be cheeper to look after if anything went bad with the bar.£800 for a replacement,
Mon Jul 28 2014 5:06pm |
Hi any chance of sending me a picture.I am offshore at the moment and i am going to attempt this task when i get home
Mon Jul 28 2014 5:32pm |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 |
A M.G.B offshore? dayrater?
Fri Aug 01 2014 11:51am |
You can do away with the ARC system, but it would be cheaper to repair your issues
Fri Aug 01 2014 5:50pm |
thanks for that.
Fri Aug 01 2014 6:39pm |
