Home > Technical > Wing mirror/reverse
redson
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Wing mirror/reverse
When i set my reverse parking wing mirror setting, it works fine - once, and then seems to have a mind of its own and screws up both settings. So when I select R the drivers side mirror does a rough approximation of what I thought I'd set it to using the memory reverse and normal settings. When I select D it adjusts itself, but far to close to the car itself, so it needs manual re-adjusting. Passenger side seems fine both R and D. Any ideas?
Post #422418 Sat Apr 26 2014 8:38pm
RRS_PAT
Apologies if this is stating the obvious
Have you saved these to memory?
Are you using the same key if set up to a memory? 2011 Autobiography Santorini Black
Post #422452 Sun Apr 27 2014 7:12am
Disco_Mikey
What year is the car? Early ones had issues with memory modules Thumbs Up
Post #422453 Sun Apr 27 2014 7:22am
redson
Yes, I saved the setting to memory. The car is 2007 TDV8.
Post #422468 Sun Apr 27 2014 9:04am
RossM
I have a 2007 and have similar issues with mirror memory and also seats. Are they both on the same memory module? 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #422546 Sun Apr 27 2014 8:06pm
redson
Yes. I've followed the memory programming process using one memory button setting. Seat seems OK. When In reverse it seems OK, but when I then select drive the mirror now adjusts to another 'reverse' setting
Post #422550 Sun Apr 27 2014 8:47pm
C11RRJ
England 2007 Range Rover Sport TDV6 HSE Java Black
+1
Post #422567 Mon Apr 28 2014 6:28am
riverblanche
just starting to get annoyed Evil or Very Mad with our rrs we both use different keys with the lazy entry
the seat adjusts fine to which ever key is used
as does the passenger mirror
but the drivers mirror has a mind of it own, sometimes goes to the full up position, or full down and sometimes when you select reverse it goes up rather than down Question
its a 2005 does that sound like a memory module Mikey?
Post #422798 Tue Apr 29 2014 9:45pm
Disco_Mikey
There was a TSB about it, with chassis numbers etc. Will try and find it Thumbs Up
Post #422820 Wed Apr 30 2014 6:03am
Ned Kelly
I started to think I was going mad as I have the same issue. 2006 TDV6
Post #422847 Wed Apr 30 2014 10:58am
