Home > Maintenance & Modifications > esf codes showing but car fine????
jsamps
United Kingdom 2006 Range Rover Sport TDV6 HSE Stornoway Grey
I have a RRS 06 tdv6 and im getting an esf message thats indicating absolute pressure failure (I think the codes p0106) problem is the car is fine and is driving the same as before the message came up! Ive had the map sensor checked,egr valves are fine and also had the turbo looked at cleaned and all seems fine? Anyone else had this before? Even the main stealer cant find out what the cause is! There only solution was to replace the turbo!!! Shocked
Any help or advice would be greatly appreciated.
John
Post #417364 Tue Mar 11 2014 7:55pm
