Home > Maintenance & Modifications > K n N panel filter/ re map TDV8
TaddyHST
England 2008 Range Rover Sport TDV8 HST Java Black
Has anybody fitted one of these filters? I ordered one the other day and just wondering people's thoughts, in particular the thoughts of those who map these cars as that's my next step Very Happy I'm thinking of heading to bell autos in York but haven't spoke to them yet.
Cheers, Tads
Post #386425 Thu Jun 20 2013 11:49am
duckworthparts
Site Sponsor
from looking at Def2 forum BAS certainly don't rate K n N filters Sophie Alltoft
Send a paypal payment direct using this link www.paypal.me/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: danroberts@duckworthlandrover.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Can also supply OEM & Aftermarket parts
Post #386426 Thu Jun 20 2013 11:52am
TaddyHST
Ooh that's interesting, maybe ile just through it in the bin then lol
Thanks
Post #386427 Thu Jun 20 2013 11:58am
duckworthparts
Site Sponsor
http://www.defender2.net/forum/topic21125.html Sophie Alltoft
Post #386428 Thu Jun 20 2013 12:05pm
mse
Ive run a K&N in the Discovery (both) and Defender (both) for ages - probably 15years, maybe 10/12...but no problems, rate them.
I service it every year (i have the kit) it saves on the filters and means i can keep it clean if i want (although it has its own service life).
I wouldnt say there are any performance increases (there might be - but i dont notice any) they have performed fine for years for me. Mike
2014 Facelift Discovery
Post #386432 Thu Jun 20 2013 12:32pm
Paddi
Re: K n N panel filter/ re map TDV8
Cheers, Tads
Re. fitting a non-standard induction filter:
After sad tales of blown turbos in TDV8s I've been researching reasons for turbo failure and a common one is apparently interfering with the standard air intake system. Anything you do that might influence air flow into the engine can affect the pressure in the induction side and potentially cause turbo failure. Any tiny bit of debris from an air filter entering the system - can cause the turbo fan blades to disintegrate. Also any oil escaping from this kind of filter can contaminate the MAFF sensors and affect engine fuelling.
Additionally - over the years every investigation I've seen into the claimed benefits of these filters on standard engines has shown them to be bogus.
It's up to you but personally I wouldn't do it.
Apparently same goes for fitting free-flowing exhausts. The changed back pressure can cause turbos to overboost. 2008 MY Java Black TDV8 HSE
Post #386475 Thu Jun 20 2013 5:48pm
mse
To do a fair test, to really make sure the K&N is not helping you have to do proper science and look at all variables and no way anyone on a forum will. I mean extremes like controlling all the factors and running two identical engines of known values. You could say that someone fitting a K&N already was likely to want something from it and this could have already been putting the pressure on turbos and increasing their likelihood of failure. etc etc
I wouldnt fit one to my sport - mainly because its under warranty, plus im not sure with more modern engines the issues are the same as older more simple engines.
I dont think K&N are actually that bad and that extreme a modification (like putting something in your oil) or those silly hiclones to spin the air (although defenders have them as standard Shocked )
But i do think they have a place and lots of people use them...the oil is harmless - i certainly didnt see any deposits from it when i looked...i think people are sometimes too cynical (like supaguard or car wax).
Fit one for the right reasons Mike
Post #386478 Thu Jun 20 2013 6:26pm
TaddyHST
Thanks for the info guys, with looking at those graphs ile be sticking with the oem filter as there's clearly no reason to change it. Strange how some cars really benifit from after market filters and others go crazy with them, all well Wink
Should I not even mention de cat options then???? Laughing
Post #386540 Fri Jun 21 2013 9:41am
Bladerider
England 2006 Range Rover Sport Supercharged HST Java Black
Paddi wrote:
Cheers, Tads
Please explain in detail how the fueling changes from a clogged up MAF would affect turbo blade life before some other engine internal had an issue. Also please share your experience with debris size versus blade life, as its something I am keen to hear about.
Internet voodoo and scaremongering aside,
Any sane person should be capable of working out for themselves that just changing an air filter without other associated changes will seldom yield any results, in fact it often is counter productive until other parts of the mix are altered to make use of the potential gain a less restrictive intake may present.
Same for exhausts although sometimes the bhp benefit comes from slight overboost or a shift in the torque curve as spool up may be affected. Certainly a decat and free flowing downpipe with a sports exhaust will represent a significant difference to how the cars OEM map was programmed and as such even the cleverest ECU's and their ability to compensate and "learn" about the individual conditions facing them at the time would then be out of their range of accuracy and hence cause problems.
So what should anyone thinking about tuning do ??
Well either go for a matched set of bits including a bespoke map to utilise them from someone they have researched and satisfied themselves knows which end of an RS232 port is which, or go for a complete turnkey option from one of the bigger tuners, or dont bother and then save themselves the pain of looking stupid on the interweb as they explain this air filter that cost £30 they got at a car show coupled with a friends cousins mates 5th hand exhaust backbox has managed to blow their turbo and kill some puppies.
Engines are just air pumps, they arent that complex really and if you believe the nonsense you read on the internet then its best you dont bother trying to mod yours !!
J. Eat. Sleep. Race. Repeat.
Post #386615 Sat Jun 22 2013 12:44am
Paddi
"Please explain in detail how the fueling changes from a clogged up MAF would affect turbo blade life before some other engine internal had an issue. Also please share your experience with debris size versus blade life, as its something I am keen to hear about"
Answer to your first question is that's not what I said.
Answer to second is that I was using the term 'researching' to mean reading around the subject. The most useful sources were the technical website pages of turbo manufacturers and specialists such as TurboTechnics for example and all of them recommend the highest standards of intake filtration as contributing positively to turbo longevity. Ingestion of any debris is given as a cause of compressor destruction and a common source is foreign bodies like pine needles or leaves left in the filter housing when changing the filter. Another common mistake is using jointing compounds on the exhaust side during turbo replacement when any excess on the inside can break off and be drawn into the turbo. 2008 MY Java Black TDV8 HSE
Post #386766 Sun Jun 23 2013 6:11pm
