Home > Technical > help please re misfuel |
No don't do it. do not turn your radio on or put key in ignition. Call LR assist and explain. 2005 Zambezi TDV6 - Gone but not forgotten
Mon Sep 10 2012 12:51pm |
Call someone who will drain tank. Do an internet search for companies keywords-misfuel diesel. 2005 Zambezi TDV6 - Gone but not forgotten
Mon Sep 10 2012 12:53pm |
Is this your MY12 RRS
Mon Sep 10 2012 12:56pm |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
I thought a small quantity was ok as long as you fill up with diesel on top of it?? |
Mon Sep 10 2012 1:07pm |
pko Member Since: 31 Jul 2011 Location: norfolk Posts: 193 |
The misfuel did activate but the pump showed 3.5 litres had been dispensed. lra have attended on recovery to garage. i had to start the engine to release park on selector. |
Mon Sep 10 2012 1:11pm |
nicedayforit Member Since: 12 Mar 2012 Location: Beside the Solway Posts: 25 |
4 litre won't make much difference if you fill the tank with diesel to dilute it. |
Mon Sep 10 2012 2:16pm |
Thanks for the advice guys, much appreciated. It has now been left at the dealers to await their report., which will be expensive. I did try to top up with diesel but couldn't get the yellow tool to reset the device, also had to start the engine to get the gear selector to pop up to engage neutral to get it onto low loader. Still, I won't do it again.
Mon Sep 10 2012 2:46pm |
Mon Sep 10 2012 2:53pm |
Im sure you dont have to start it to be able to get it out of park and you certainly dont need to to remove the handbrake,
Mon Sep 10 2012 3:44pm |
The dealers will almost certainly say you have to replace Hoff, fuel lines, maybe even injectors and of course if you don't it will void the warranty....
Mon Sep 10 2012 4:36pm |
It's been done dozens of times, keep topping up with diesel, it will not be problem, always add some 2 stroke oil if it makes you feel better In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Mon Sep 10 2012 5:09pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
4L in an 80+L tank? I'd have brimmed it with diesel and carried on. That amount won't reduce the lubricating ability of the fuel (which is the problem if petrol is used in a modern common rail diesel as the high pressure pump and injectors need the fuel to act as a lubricant as I understand it) to the level that damage would occur. And even if it did slightly increase the long term chance of a fuel pump or injector failure, how could LR prove a misfuel of that small amount 2 or 3 years down the road?
Mon Sep 10 2012 5:11pm |
Hi, bodsy, that would have been my first choice, but neither me or the pump attendant could reset the miss fuel device, so
Yeah but whats been suggested to be replaced may require you to ring your insurance company!...its not going to be cheap. I might be tempted to have a word (subject to the bill) with LR as their miss fuel device failed to safeguard against miss fueling Mike 2014 Facelift Discovery |
Mon Sep 10 2012 6:45pm |
