Home > Technical > Digital fuel gauge fault
riverblanche
Hi,
our 2010/60 did the same while under "L/R Approved Warranty" and CCP refused it as a warranty claim as known issue Twisted Evil the dealer contacted CRC and they authorised the repair (sender wires)
so may be worth mentioning get L/R to pay
it has been mentioned that car could go into limp mode if it "thinks" its going to run out of fuel so sooner rather than later may be best
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #542637 Mon Dec 04 2017 6:04pm
aljo
TECHNICAL BULLETIN
LTB00566v6
04 JUL 2014
© Jaguar Land Rover Limited
All rights reserved.
This reissue replaces all previous versions. Please destroy all previous versions.
This bulletin supersedes TSB LTB00566v5/2014 dated 03 APR 2014, which should either be destroyed or clearly marked to show it is no longer valid (e.g. with a line across the page). Only refer to the electronic version of this Technical Bulletin in TOPIx.
SECTION: 310-00
Fuel Gauge Operation Not Accurate
AFFECTED VEHICLE RANGE:
Freelander 2/LR2 (LF)
Model Year:
2007-2012
VIN:
7H000634-CH292666
Discovery 4 / LR4 (LA)
Model Year:
2010-2013
VIN:
AA510178-DA656034
Range Rover (LM)
Model Year:
2010-2012
VIN:
AA304426-CA369495
Range Rover Sport (LS)
Modl Year:
2010-2013
VIN:
AA212145-DA790997
MARKETS:
All
CONDITION SUMMARY:
Situation:
A customer complaint of the fuel gauge not working or the gauge is not accurate.
Please advise the customer, if possible, to bring the vehicle in with the fuel tank level below 1/4 full.
This Version has been issued for a change to the Service Instruction.
Cause: Fretting corrosion across the fuel level sender harness pins inside the fuel tank. Suggested Customer Concern Code - L69.
Action: After completing primary diagnostics and where the cause is not identified, follow the Service Instruction below. Any issues found during the primary diagnostics must be carried out as a separate warranty claim.
Post #542642 Mon Dec 04 2017 6:18pm
Can still email a pdf copy of complete bulletin if wanted, not sure what I'm doing but have managed to upload PDF file to my gallery as well. Need to work out how to add to post sometime. Might help anyone else who has similar problems.
Post #542657 Mon Dec 04 2017 7:54pm
foxtrotzulu
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
My 2010 RRS developed this fault. Fuel gauge suddenly reads empty, then works for a while and then reads empty again. I've just had it repaired as per the tech bulletin above - i.e. a fault with the connectors.
However, a word of warning ..... My RRS developed this problem a couple fo weeks ago and I thought it was no big deal. Just book it in for a repair when convenient and in the meantime make sure it doesn't run out of fuel. But... the vehicle ground to a halt a couple of days ago. Shuddering and regularly stalling. Had it recovered to the garage where they said that because the vehicle thought it was out of fuel the engine management system started shutting it down to protect itself. I'm still a little surprised this was the case, but it seems to be so. Beware!
Post #558301 Wed Jun 06 2018 1:55pm
Grizzly_Al
United Kingdom 2009 Range Rover Sport 3.0 TDV6 HSE Galway Green
Just had this very same problem with my 59 plate RRS, its only been a day so far, do I have to drop the tank to get to the sender unit ? I tried removing the rear seats to see if there was an inspection cover but couldn't find one Sad
I'm guessing I'm going to need a new sender ?
I've tried searching the technical bulletin but haven't really had any luck
anyone else managed to fix theirs themselves ?
many thanks
Alan.
Post #623724 Wed Apr 20 2022 7:04pm
Oldandconfused
From memory, there are 2 senders in the tank.
yes you have to drop the tank.
My MY10 cut out and I had to have it recovered (the recovery driver misdiagnosed it as the LP fuel pump) and as it was at the garage anyway I had the parts replaced. I understand the wiring can be remade to save cost, but I don't have the skills (and have an iffy back) to do it myself so it was easier, if more expensive, to have the garage repair it.
Post #623732 Thu Apr 21 2022 6:59am
https://drive.google.com/file/d/15vRZH1JCy...sp=sharing
Post #623734 Thu Apr 21 2022 7:25am
Grizzly_Al
Awesome thank you guy's Thumbs Up
Post #623796 Sat Apr 23 2022 9:51am
