Home > Maintenance & Modifications > RRS TDV8 57 plate Coolant level Require Top up Every 10 days |
kennyt0804 Member Since: 18 Oct 2011 Location: Prudhoe Posts: 12 |
I am having to top up coolant level on RRS TDV8 every 10 days about 500ml each time. Any ideas??
Thu Nov 03 2011 8:22pm |
Egr cooler leaking |
Thu Nov 03 2011 8:48pm |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
There was a replacement expansion tank for '57' plate RRS as there was a fault with some. Mine was replaced a couple of years ago as mine kept doing that. Sons of dogs come hither and get flesh
Sat Nov 05 2011 1:31pm |
Bearrubb1 Member Since: 02 Jan 2014 Location: Kettering Posts: 3 |
Kenny any news on the leak?? My 08 tdv8 is doing the same?? |
Thu Jan 02 2014 5:46pm |
Carlos3 Member Since: 14 Apr 2013 Location: Chester Posts: 40 |
Had a similar problem with my TDV8 last year
Sun Jan 05 2014 9:27pm |
Took mine in today Carlos hope they find it as pressurised mine twice and no leak told them to check where you said, fingers crossed |
Mon Jan 06 2014 2:53pm |
Hope you get it sorted. |
Tue Jan 07 2014 6:24am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
I had a very slow loss of coolant on my 57 plate TDV8. Turned out to be a leak in the manifold that connects all of the coolant pipes in the V below the EGRs. 2012 SDV6 - it's missing a couple of cylinders
Tue Jan 07 2014 8:44am |
Was it replacement manifold?? Where did you get it fixed |
Tue Jan 07 2014 5:29pm |
