Home > Australia & New Zealand > Wheel bearings and Hubs
Jimmy Salsa
Australia
Just going through the process of getting the car ready for our big trip through the Kimberley only to discover that both front bearings and the rear passenger side are shot.
Interestingly I also discovered that you can't just replace the bearings on the front and actually have to replace the entire hub.
Waiting on the parts quote but am not expecting too much joy there.
Anyone else had to do their wheel bearings as yet?
I suspect that there may have been a few hundred too many dunkings in rivers and mudholes running on very hot bearings over the last 80,000kms. 'Black Betty' Java Black RRS 07 TDV6
Post #299925 Thu May 19 2011 1:03am
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
JS, not heard of this before, and most i hear at the 80K mark is typically the control arm bushes are usually shot and need replacing.. that happened on my last one
Jim Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #299996 Fri May 20 2011 6:39am
tempestv8
Australia
Hi Jimmy,
How are you determining that the wheel bearings are shot?
If they are the same like the Disco II wheel bearings (sealed for life Timken bearings) then they are really quite durable and have been very much troublefree despite being subjected to punishing offroad condtions. My wheel bearings have crossed the Simpson Desert twice, submerged in countless bog holes and still are OK.
But be warned - like any wheel bearing, they cannot handle a big side swipe. I've killed one rear wheel bearing that way.
I think the test is to jack up a wheel and then shake the wheel from side to side and do the same top and bottom. If there's significant play, maybe they are stuffed. 1999 Discovery II V8 auto
Post #304560 Thu Jun 30 2011 1:44pm
MikeS
Australia 2005 Range Rover Sport 4.4 V8 HSE Tangiers Orange
I've just had the passenger side rear replaced, nearly 2 days of swearing and heating for my indy to get the hub carrier off. Both fronts are beginning to grumble under braking but they're a much easier fix, £120 for a complete unit is a damn sight cheaper than the £350 it used to cost for my P38... Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne.
Post #306316 Fri Jul 15 2011 7:22pm
