![]() | Home > Maintenance & Modifications > jacking up issues with a RRSport |
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 ![]() ![]() ![]() |
how else do you fix a puncture? |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 701 ![]() ![]() ![]() |
yeah exectly! hav u fixed a puncture on yours tho? |
First I've heard! 2005 Zambezi TDV6 - Gone but not forgotten
u think its just them talkng rubbish VA? The guys at the local tyre shop wudnt balance my wheels last week for rear of jacking it up and damaging the airbag they said |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 ![]() ![]() |
Use a different garage............it sounds as if they are just incapable and resistant to the brand for whatever reason. AS VA has stated, not heard of issues. L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now! 5 series for the miles ![]() RRS S/C factory built HST - Gone 45 others have been and gone! |
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
Use the LR jack or trolley jack under suspension arm. |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 ![]() ![]() |
No problem with this on D3s, sounds a load of rubbish to me. I change my wheels often either with an airjack or trolley jack under the chassis rail. |
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 ![]() ![]() |
Remember if changing the near side rear to be careful where you put the jack.....loads (me included) have put the jack in the wrong place and damaged the air suspension pump bracket!!!
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 ![]() ![]() |
They are probably worried about the capability of their equipment and liability, as the jacks will be lifting to almost their max height and these cars are very heavy and very expensive. When I had some tyres changed the guys at my tyre place were jacking away for ages before the wheel came off the ground |
Thought U peeps had butlers to do things like changing wheels!! |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 ![]() ![]() |
On my MY2011 RRS the book says to ensure offroad height is selected before jacking up. I did that when changing to winter wheels and tyres and have had no problems since. |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
I just had a puncture and jacked the car up from its lowest access setting without a problem and then changed the wheel over later at work with the suspension on normal again no problem. There used to be a big problem with the old P38 Range Rover and that is probably what they are thinking about. |
Sorry Kensta but this sounds like the joke of the year! |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
