Home > General > adaptive and non adaptive headlights hotswapable? |
crowej Member Since: 21 Apr 2008 Location: Dublin Posts: 289 |
are adaptive and non adaptive headlights hotswapable? i currently have non adaptive but have oportunity to pick up some adaptive cheap |
Sat Feb 21 2009 7:50am |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
They should be swappable, but they won't work any different than your current headlights unless you also install the necessary AFS control module, which must be wired through private LIN bus to the adaptive power module within each headlight assembly, and to the rest of the car's electronic network via CAN bus. You'd probably need to get the dealer involved for all that wiring and connecting - you can bet that a software upload to reconfigure the system would be required after all the hardware is in place - and I reckon it would turn out to be quite an expensive modification. |
Sat Feb 21 2009 8:17am |
DiscoStu Member Since: 10 May 2006 Location: Essex Posts: 47 |
Not swappable - and you can't just plug them in and use them as normal lights as the motors won't hold the lights up. They'll be pointing at the floor. A D3 not in drag....
Sun Feb 22 2009 8:20pm |
