Home > Maintenance & Modifications > 20" tyre pressures |
What customer care told you is just wrong - did they never hear of the Dynamic Pack? You can spec that for your TDV6 and that has 20" wheels as part of the deal. Sorry I can't help with the pressures - should be the same as the pressures used by the SC folks, I think.
Fri Jan 06 2006 6:22pm |
If you don't want them and RR say the make your warranty void tell your dealer this and get them changed at cost to the dealer who should never have fitted them. 2005 Zambezi TDV6 - Gone but not forgotten
Fri Jan 06 2006 6:23pm |
stilly Member Since: 27 Dec 2005 Location: England Posts: 4 |
I do want them - they look ace with SC grille and vents. Just want to get the pressures right, about to have Turbo chip upgrade so will be pushing the big old unit a bit harder than before and every little helps.... |
Fri Jan 06 2006 6:35pm |
Like schmoogle I suggest you check with the SC boys. 2005 Zambezi TDV6 - Gone but not forgotten
Fri Jan 06 2006 6:55pm |
PaulB Member Since: 10 Dec 2005 Location: UK Posts: 546 |
There is a stick-on label on the inside of the driver's door that gives front and rear tyre pressures for all wheel and tyre sizes.
Fri Jan 06 2006 7:16pm |
Thanks for that,
Fri Jan 06 2006 7:48pm |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
Ouch! I nearly got caught out by that in Sept. Phoned LR they said no can't have dynamic pack on Tdv6, so I put order in. Then 3 weeks later just happened to go on LR web site where it said it was avail. So I cancelled the order and reordered, but production didn't start till Dec. TDV6 - gone
Fri Jan 06 2006 9:31pm |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 |
I run mine at the recommenced pressure for the twenty inchers as fitted to the supercharged models and have no problems. The sticker for the pressure you need is on the inside of the drivers door. Its out there somewhere. Second V10 Treg on the drive at the moment. |
Fri Jan 06 2006 11:39pm |
smudge Member Since: 12 Aug 2005 Location: East Horsley Posts: 83 |
I also have 20" SC FE wheels fitted to my TDV6 HSE and the LR dealer did not say it invalidates the warranty - as I specifically asked about this.
Sat Jan 07 2006 11:58am |
