Home > General > fuel burning heater
Page 1 of 3 123>
autolines
2005 Range Rover Sport 4.4 V8 SE Cairns Blue
fuel burning heater
wonder if anyone can help me?
both myself & a friend both have RRS's mine is an SE ex demo model with everything the HSE has bar for the wheels, my friends is an HSE. our problem is that although I have a webasto heater clearly visable I have yet to see the smoke from uder the passenger wheel arch which tells me It has yet to kick in, I must admit to starting her up & prety much driving off within say 2-3mins & I havent had the vehicle long & to be honest we havent had much below 3-4 degrees. My friend on the other hand drives 3 miles to Mcdonnalds & sits on the drive way in a cloud of smoke, he cant seem to get his to go off. Is there a tech sheet which gives the spec as to when it should kick in or anything that tells you more than the handbook?
Post #74756 Fri Jan 12 2007 8:48pm
The FBH will activate at 5c. As it has been fairly mild recently I doubt yours has kicked in. 2005 Zambezi TDV6 - Gone but not forgotten
Post #74758 Fri Jan 12 2007 8:54pm
ENVOY
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Arctic Frost
The FBH should come on at 5degrees some of my Previous cars
P38 Range Rover Autobiography
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
RRS 3.0 HSE BALTI BLUE
current vehicles
RRS 3.0 L494 Autobiography
Audi R8 V10 Spyder
AC Cobra
Landrover Defender 90
Landrover Defender 110
Suzuki Jimney
Post #74759 Fri Jan 12 2007 8:55pm
autolines
Thanks for the Info.
I maybe have to sit a little longer to see if it works next time im below 5deg
I presume it goes off on the move?
Post #74760 Fri Jan 12 2007 8:58pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
If your aircon / auto climate control is switched off (off button below the radio - next to the"Econ" button). Your FBH will not work. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #74761 Fri Jan 12 2007 9:07pm
MAW
I see mine regularly... aircon always on low also kicks it in...
seems quite fierce somedays and smells well!!
Post #74799 Fri Jan 12 2007 10:21pm
Tim in Scotland
I've never seen exhaust smoke from mine, or the FFRR I had before it whereas the TD4 Freelander always had a telltale exhaust on colder mornings.
The FBH on my IS working as I have heard it cut in as soon as the sensor has realised that the outside temperature is lower than 5C. It hasn't had to do much work so far this winter that's for sure! Had a few frosty mornings back in November otherwise it has be very mild and wet here. Just got home at 0115 and even though there isn't a cloud in the sky and I can see loads of stars, it is still 8C here according to the car temperature gauge.
I have noticed with the Climate Control left in auto that it takes an age to get warm inside the cabin, but if I press the face level and footwell buttons on the left of the consol and leave the climate switched on with one light on the centre knob then I get warm air much more quickly, even faster than when I press the "econ" button. Have never switched the climate/ac off as far as I know! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #74804 Sat Jan 13 2007 1:31am
bkehoe
Ireland
autolines, do you have a TDV6 or a V8? Your profile says you've got a V8, and V8s don't have a FBH...
Post #75325 Mon Jan 15 2007 12:50pm
MikeP
What may I ask is the Fuel Burning Heater? What does it do? Michael Potter
Rangey Lover/BMW Driver
Post #75465 Mon Jan 15 2007 8:05pm
It heats the diesel up on a cold morning. Basically when it's cold diesel can turn into a gel like substance - this prevents that. 2005 Zambezi TDV6 - Gone but not forgotten
Post #75466 Mon Jan 15 2007 8:10pm
ENVOY
VA i might be completely wrong but i think it helps warm the water system up not the diesel, there are systems that will warm diesel up but i dont think its fitted to the RRS,
All white diesel has an anti gelling agent in it some of my Previous cars
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
current vehicles
Audi R8 V10 Spyder
AC Cobra
Suzuki Jimney
Post #75468 Mon Jan 15 2007 8:17pm
Martin
Site Administrator & Owner
Incorrect VA, to the stupid corner with you...
What it actually does is burn diesel in order to warm up the engine coolant quicker - meaning that the cabin and the engine itself warm up much quicker. The reason for fitting it is because modern diesels take absolutely forever to warm up otherwise! Like this site? Buy some RRSPORT goodies to show your support!
Post #75469 Mon Jan 15 2007 8:18pm
MikeP
Oh right ok. I didnt realise they took a long time toheat up. I assumed they were just like petrol but more economical.
Thanks very much! Michael Potter
Post #75475 Mon Jan 15 2007 8:32pm
Martin,
I'm led to believe both you and VA are correct. Aswel as your explaination, one of the by products of a FFH is to heat the diesel engine up quicker making is more efficient - in case of Toyota, they are different systems depending on the climate of the region of sale
Post #75476 Mon Jan 15 2007 8:37pm
Tim in Scotland
Also by making the engine warm up more quickly the emissions are reduced, which is more important these days than warming up the driver (who has electric heated seats to warm his bum anyway!) Cannot wait for the timer unit to become available............... greener engine on cold mornings AND a warm car to get into 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #75477 Mon Jan 15 2007 8:43pm
Page 1 of 3 123>
