Home > Maintenance & Modifications > Leaking air tank on L320 sport + leaning to ns
Hightimo
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
I’ve discovered a small leak on the air tank for the suspension, so replacement tank ordered. However would this cause the car to lean over to the left - it’s about 25mm lower on the ns than the os. Only warning is dash stating normal suspension height only, and the front takes a while to raise when heights changed . The car will get to all 3 height settings but is slow to raise front. All sensors show ok on 4x4 screen
Post #622247 Fri Feb 25 2022 10:19pm
Hightimo
Update - a suspension calibration sorted the leaning issue👍
Post #622735 Sat Mar 12 2022 6:23pm
Hightimo
And a air compressor drier kit with new filters sorted the slow height rising
Post #622737 Sat Mar 12 2022 6:24pm
Hightimo
Update - ended up fitting a new compressor to solve the issue- old compressor was just knackered in end ! Put a cheaper replacement one on but similar to the hitachi one as it still has the original one on it - came with a 2yr warranty so fingers crossed !
Post #624127 Mon May 09 2022 3:54pm
