Home > General > 2010 TDV8 cranks but doesn't start
Page 3 of 3 <123
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Hopefully they will sort it out for you, just hope it doesn't take too long.
Post #619881 Fri Dec 10 2021 5:32pm
aaronjb
They did say that if the problem turns out to be the instrument cluster, it likely won't be repaired this side of the new year.. but of course it could be many other things! 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #619882 Fri Dec 10 2021 6:11pm
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Taking this to jas landrover york would be the best decision you could ever make.
Post #619884 Fri Dec 10 2021 8:48pm
aaronjb
Car is now back from Avenger 4x4 in Peterborough - fixed for the princely sum of £536.
On inspection they found the tank full of what (in their opinion) is about a 50/50 mix of petrol and diesel - which is weird, because the last thing I did before it stopped (literally at the pump) was fill the tank from empty (fuel light on) with diesel.
The lift pump (in tank pump) had died, so it was treated to a new one of those and fresh diesel. Still didn't start.
They found that some connections on the underside of the fuse box (in the battery box) were corroded - cleaned and.. fired up.
Still not entirely sure I trust that the weird CANbus fault hasn't just fixed itself only to reappear at some inopportune time in the future, but we'll see. It'll take a while for the confidence in it to come back, I think; the only question is whether or not I end up selling it because I don't trust it, or keep it longer term.
Still, at least it works again. For now. It's a JLR product so I'm sure it won't be long until it breaks again (so every garage I go to tells me, anyway, including Avenger!). 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #620079 Fri Dec 17 2021 4:52pm
Boxers
Fingers crossed it doesn't break too soon ! Glad Avenger got it going for you.
Post #620080 Fri Dec 17 2021 5:09pm
Page 3 of 3 <123
