Home > Maintenance & Modifications > Suspension Control Unit
HughN
Wales
In an attempt to get rid of "Suspension Fault", I need to replace the air suspension control unit. Looks like it'll be a lot of fun getting access!
Will I need to do any jiggery-pokery with a computer afterwards, for example is it VIN-locked?
Thanks,
Hugh
Post #618580 Sun Oct 31 2021 5:15pm
The workshop manual says that the new unit needs to be "initiated", whatever that means. You'll also need to calibrate it to the ride height sensor settings - maybe that's what they mean by initiating it.
Be careful when removing the connectors - I had a transient issue with my TDV8 that ended up being a loose wire that appeared to have been loosened by a tech pulling on the wires when undoing the plug. 2012 SDV6 - it's missing a couple of cylinders
Post #618600 Mon Nov 01 2021 9:50am
HughN
Wales
Thanks, Wayne.
I hope the local indie does house-calls to my SORNed vehicle!
Post #618610 Mon Nov 01 2021 11:12am
