![]() | Home > Maintenance & Modifications > Anti roll bar bushes and drop links |
Bertbuckie Member Since: 04 May 2021 Location: Scotland Posts: 274 ![]() ![]() ![]() |
Any suggestions as for brands? Polly, oem?
Thank you Old and confused |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
No problem, I would like to be able to tell you which poly bushes he put on the rear but the, substantial (I had lots of other work done), bill just says rear polybushes and they are orange.
MartinsTDV8 Member Since: 22 Feb 2017 Location: County of Sutherland. Posts: 140 ![]() ![]() ![]() |
I fitted genuine LR ARB bushes to the front, and after 6 weeks it was knocking badly. I was advised my DISCOMIKEY to replace them with PRO Poly bushes as they have a larger diameter, so I did. The knocking has gone, and I’m well chuffed. All the other bushes and lower arms are genuine LR parts and seem to do what they are supposed to. Previously owned 1999 Disco 2 TD5 Disco 3 HSE TDV6 2007 Gone 2007 TDV8 RRS1 in Buckingham Blue. How do know if the knocking at the front has been sorted? You can hear the knocking at the rear better |
Thanks all, I will order when home |
https://www.rrsport.co.uk/forum/topic57452.html 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Cheers twinkle |
I’ve got a little knocking too especially over the plastic sleeping policeman at work. Gently crawling over and there is a knock which my super hearing has now detected a fluttering of knock on bumpy B roads. I had a load of bushes replaced last year but my indie couldn’t see anything amiss. So I’m waiting on it becoming more prominent and then take it back. 2006 2.7 TDV6 HSE in Cairns Blue. |
Having looked at Buckster's thread, I think I have the orange Polybush's on the rear. When the front ones go again, as I'm sure they will, I'll get them put on there as well.
Cheers again. Top tip... never drink a bottle of vodka in a night.... now I have to both suffer a hangover, and the wifes driving today 😭 |
