Home > Technical > Sport won't start if left for a day
Taff814
United Kingdom 2005 Range Rover Sport TDV6 HSE Orkney Grey
Help!! My 2005 2.7 Sport won't start if its been left for more than a day. I've replaced the battery and nothing has changed. Its got to the point that I'm planning to get rid of it.
Does anyone have any ideas of the problem? And, just to compound the problem, the car is in the UK and I'm stuck in Saudi Arabia so it's my wife who's having to jump start it every time.
Post #610425 Tue Feb 23 2021 2:40am
garrycol
Australia
So it starts if jump started - sounds like a battery issue (yes I see you have replaced the battery but if it needs jump starting it is a battery issue. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #610426 Tue Feb 23 2021 3:26am
Smarttech
If the battery has been changed and it's any good then that would point to something is being left on or not shutting down and drawing current to flatten a battery in 24 hours.
Or could be a duff battery that's been fitted, it happens. 2017 SVR. SVO Scafell grey Ebony interior
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #610428 Tue Feb 23 2021 7:09am
riverblanche
sadly dont think we have enough details as both have said above suggests battery or a battery drain
full marks to swmbo for the jump starting can you get her to check the voltage before she unlocks it (while its still asleep)
that would tell you if the battery has held a charge or been drained.
if you have twin tow electrics that is an easy place to check
How far is it been driven after starting as to recharge a near flat battery will take a fair amount of time/miles depending what is being used (heated seats)
It could be its just not getting charge up enough so by the next day its toooooooo weak to start, time for a smart charger maybe
(have I mentioned the tow socket yet Laughing )
if its spinning over and over and needs the jump to keep going before it starts it could be heater plugs (although it has warmed up a bit the last few days)
get swmbo on the case
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #610466 Tue Feb 23 2021 5:08pm
Taff814
Thanks to you all for your replies. I'll have a chat with her about testing the voltage before she opens the car. This is the second new battery its had in 5 months. Previous owner changed it in Sept
Post #610527 Wed Feb 24 2021 1:15pm
How long are the drives when it is jump started? If it's short journeys then the battery will never recharge. Indeed, it's possible that the alternator is dying and the battery has no chance to recover.
If checking the voltage via a tow socket isn't in SWMBO skill set, just have her check the battery voltage after unlocking the car. This will still give you a good indication of the state of play of the battery. Then, once it is started, check the voltage again and that'll give an indication of the alternator's state.
A weak alternator, short journeys and cold conditions would be the perfect recipe for a dead battery. 2012 SDV6 - it's missing a couple of cylinders
Post #610529 Wed Feb 24 2021 1:29pm
evets
The secret menu on a range rover tells you what voltage the battery has.
12.3v is low charged battery 12,6v is half charged 12.9v is fully charged
when running you should get 13.5+ volts. At best 14.1v?
Post #610603 Thu Feb 25 2021 10:02pm
Taff814
The battery has been as low as 10v when I checked it during the brief 4 weeks I spent in the UK last year. It goes up to over 14v when its running. My wife does tend to do short journeys in it. I've been looking at a new Bosch battery with 110aH and a CCN of 920. I'm thinking this'll be a bit beefier and shouldn't run down so much between drives
Post #610618 Fri Feb 26 2021 9:55am
1richard1
If it due to the short journeys it will kill the new battery, as mine only get used once in a while i got a halfords solar charger put the solar on the window screen and the other end chargers through the odb port.
Post #610625 Fri Feb 26 2021 12:10pm
riverblanche
so thats 3 of us that mention Short journeys are not enough to keep a battery in good health Thumbs Up
even if you put another new battery on if the journeys are not long enough it will just fail as well
(it will just take a bit longer to get to that point)
Short journeys are not good for a big diesel engine (DPF for one thing Whistle )
it can take 10-15 miles and 20-30 minutes just to get the Oils up to a normal temp
Looking at a way of charging it may be money better spent Question
Post #610634 Fri Feb 26 2021 2:16pm
evets
The correct battery for a Range Rover Sport is: H80 90amp/hr
Post #610643 Fri Feb 26 2021 5:25pm
evets
Sounds like the charging system is in order 14v good
Post #610644 Fri Feb 26 2021 5:28pm
evets
One point not mentioned has the Red battery light been coming on. If not as mentioned
there is a drain on the battery
Post #610645 Fri Feb 26 2021 5:33pm
Taff814
My wife tested the voltage across the battery after she returned home. It was 12.3 so she put it on charge. This morning I’ll ask her to test it again then start it and check once more while it’s running. At least that will rule out the alternator. Thanks to you all for your help and advice.
Post #610670 Sat Feb 27 2021 4:55am
Eaters
It does sound like a Ctek charger (or longer runs) might be a better investment than a new battery. But lets hear what your wife discovers regarding voltage Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #610680 Sat Feb 27 2021 8:11am
