![]() | Home > Maintenance & Modifications > Help ...Incorrect Power Steering Fluid? |
KozzyH Member Since: 18 Dec 2020 Location: Northamptonshire Posts: 3 ![]() ![]() |
Hi all
Yes, I guess so as the noise has gone now. So the fact that the reservoir amount was less than minimum, does that suggest a leak?
Its not going to cause an issue in the short term - as said any oil is better than none if it is low.
