Home > General > Throttle body problem
mgrover
When the car was apart I think the throttle body plate was opened and closed. Now whenever I floor it the car cuts out completely. But not when in Park.
I've attached the error codes. Do I need to reset the throttle body somehow?
Post #607331 Tue Dec 08 2020 7:23pm
Interesting.
Do these have a mechanical cable between pedal and throttle body ?
I know the throttle iitself is electric
I guess it’s worried the throttle is open too far and cuts the engine
Does it drive ok apart from that ?
Unplug the throttle pos sensor and reconnect
Better monitor the live values. There are 2 tps readings. They should follow each other fairly closely
Post #607332 Tue Dec 08 2020 7:54pm
mgrover
I think it's all electric. Also my fuel trims are constantly at 20%. So if the plate is open too much at idle then it'll be open too far at max throttle. Anyone know how to reset it? I have gap and the dealer software
Post #607333 Tue Dec 08 2020 8:06pm
Could be part of the issue.
Post #607334 Tue Dec 08 2020 8:11pm
mgrover
The thing is it works fine in Park? Or does the throttle body not open fully then?
But the fault occurs the idle basically Censored up, no longer steady. But I can clear the code there and then and it goes back to normal. So not a mechanical problem I think.
Post #607335 Tue Dec 08 2020 8:16pm
At idle the throttle will only open a little bit. Even if you rev it
I don’t think You can do a software calibration.
Post #607336 Tue Dec 08 2020 8:27pm
mgrover
I've ordered a 2nd hand throttle body for like 30quid. I'll see how it goes. But it's the only thing wrong. Am tempted to just get a brand new one. But car will be off for a few days to get its alloys redone
Post #607338 Tue Dec 08 2020 8:37pm
mgrover
Also does anyone know what the values for the throttle are meant to be at idle?
Post #607339 Tue Dec 08 2020 9:02pm
About 3% when cold.
Reducing when warm.
Or do you mean voltage ?
They should match
Post #607340 Tue Dec 08 2020 9:05pm
mgrover
Yeah it's about 3% from what I remember. I think what happens is when I floor it it skips a gear due to damage and ends up opening too much.
I've also attached a picture of the throttle body
I dunno if also related but the cars just had the 10% sc pulley installed
Yet another edit, this is my idle, not sure which one I need but looks bad :p
Post #607341 Tue Dec 08 2020 9:56pm
mgrover
small update it now also throws the p2101-29 code. and i can make it reproduce in park just by opening more throttle. am just waiting on a replacement TB and we'll see how it goes. I might just connect the new TB in terms of electronics and see if itll operate in key mode 2?
Post #607407 Fri Dec 11 2020 8:44am
I can see the problem.
Track 1 and track 2 should be the same voltage. (or very close)
Yeah connect the replacement up to see if it works
Post #607410 Fri Dec 11 2020 11:09am
mgrover
am just hoping this fixes the issue. but now the car runs lean AF like 20% all the time, am hoping thats due to throttle body but the TB is past the MAF so not sure if the TB is taken into account when calculating trims.
Post #607411 Fri Dec 11 2020 11:30am
It’s much worse than before is it? In terms of %
Has it gone the other way + to -
Do another smoke test if you have the equipment
Post #607412 Fri Dec 11 2020 11:37am
mgrover
its way worse than before, idle is just constant 20% short term and long term is around 22%. So am hoping its the TB issue. The first thing I did was smoke test, showed nothing at all.
Post #607415 Fri Dec 11 2020 11:45am
