Home > General > L494 2015 HSE Right headlight out, fuse ok, no errors i
toti62
Iceland
2015 RRS HSE headlight Right side is totally out, no warning in dash. No turn, signal no DRL and no headlights hi or low. Fuse is ok. No error on dash. Any ideas????
Post #606570 Thu Nov 12 2020 5:49pm
Red Arrow
Either the main headlight earth under the wing or the headlight control module Thumbs Up
I had a similar issue and was the earth , I have a spare module if you need one
Post #606572 Thu Nov 12 2020 7:43pm
toti62
Iceland
Do you have the partnumber for this headlight module, and how much do you want for it?
Post #606578 Fri Nov 13 2020 8:57am
Red Arrow
PM Sent Thumbs Up
Post #606587 Fri Nov 13 2020 11:36am
toti62
Iceland
Well I have found out the problem, the thing is that each headlight has a ground cable attached to the body, Inner fender to be exact. That connection is located under the wheel well shield on each side. so you would need to remove the wheel and remove the plastic wheel well shield to access the cable. This cable had corrasions so when pulled it broke completely. I got this fixed for both sides. So now you know what to look for when your headlights die on you. Thanks for the help.
Post #606603 Fri Nov 13 2020 6:04pm
Red Arrow
Thats what I said on my first post Thumbs Up
Glad you got it sorted
Post #606608 Fri Nov 13 2020 9:49pm
